I have a little 1440x1440 display to run with MB/rpi4. I don't see an option in the config settings for this resolution or to make a custom resolution. How do I get it to display?
1 - 2 (2)
Hi @PRiCK
Are you sure the resolution of your display is really 1440x1440? Cause I've never seen or heard of square display with such a resolution
Could you post me a link to the exact display you are using?
