The Fan speed isn't reading at all for the dubbadhar theme, its saying “NaN” on my RasPi and showing an error on the MoBro software. Anybody know the fix? I already downloaded the HWiNFO and got it set up if that helps.
1 - 1 (1)
Hey @OzzMann80, you can try using the new dubbadhar theme in the version 1.0.0-beta6. Check out our blog post about it here. Maybe you can find the fan speed there.
