Dubbadhar theme is not responsive
Van
Hi everyone,
I have just started with MobBros. The installation is easy and all themes are working great with my Raspberry Pi 4 + 3.5 inch LCD (480x320). However, I have an issue with dubbadhar theme (the dubbadhar old is showing properly).
As you can see from the attached picture, the dashboard was cropped in. The same happen with Raspberry Pi and local preview on my browser (http://localhost:42100/?uuid=MoBro).
I have searched through the forum posts but cound't find similar issue. Could you advise how to fix this.
Thank you!
Hi @Van, the widgets in the dubbadhar theme are positioned absolute with pixels, if you change the resolution you can use the coordinates per widget to reposition and resize the widget as you like.
