Enabling Screen Saver
I didn't enable the screen saver at first set up. I want to enable it now. I've changed the display_screensaver=disabled to display_screensaver=enabled in the default config, but it still doesn't launch. Do I have to add this line in the config file?
Hi @Brandon V
That is not how you are supposed to alter the configuration.
Some of the values are applied straight away (and might break the service if you provide incorrect ones) while others need to be passed to a script first to be successfully applied
‘display_screensaver=enabled’ is not a valid configuration entry
If you want to change the configuration after the initial setup you can just open the setup page again at any time.
Just type the IP address of your Raspberry Pi into the address bar of you browser as described at the bottom of the page here: https://www.mod-bros.com/en/faq/mobro/raspberry/setup
Got it, thanks
No problem
Glad to hear it works for you now :)
