Getting "MODBROS MONITORING SERVICE NOT RUNNING"
I tried to use the application but run into this issue… no matter what I do it wont show any data and just show this message “MODBROS MONITORING SERVICE NOT RUNNING”.
Tried reinstall, run as admin, restart… nothing worked. services.msc also does not show a running task.
Any ideas?
Hi @digaus
Could you open the services list again and check if a ‘ModBros Monitoring Service’ is listed in there and whether its running?
Also you are running Windows 10 right?
Hi @digaus
It seems that the cause might be the name of my user. It has a special character in it (&). When running the service with admin rights through CMD it worked.
Maybe you can reproduce it when you use special characters in your folder structure.
Yeah I've tried with a separate user using spaces and also special characters but for me the installation was fine.
We're looking into it tough as this issue has come up multiple times now.
