Is there an easy way to display data with a decimal instead of rounded up?
I wanted to display the Vcore of the GPU from HWInfo - and would like to see values such as 0.850 V but it will always be rounded up to 1V in the Modbros app. Is there an easy way to display data with a decimal instead of rounded up?
Found a solution to this on my own. In HwInfo → right click GPU core voltage → customize values → multiply by 1000, then customize the Unit → mV. Now displays the actual millivolts used.
Thx man !  Hopefully they will fix so this will be an “out of the box”  solution but this will do fine for my purposes :)
Aalkul
Yeah, I agree with you. I will try to report this as a feature improvement.
In the meantime, whenever you upgrade HWInfo, make sure to back-up the “HWiNFO64.INI” file located in the installation directory and copy it back if you install the upgrade on the same directory.
