Modbros desktop app will not start whatsoever.
Hi guys,
I've been having all the joys in the world with ModBros. However, it suddenly just.. doesnt work anymore. It doesnt start up, and my rasberry pi doesnt connect to it anymore either. I found this post: https://www.mod-bros.com/en/forum/t/modbros-wont-starts-anymore~1414
I tried this, did a clean reinstall of modbros, but no succes. Any idea's what i could try? Thank you.
Hi @massive_E
when trying to start the application, does the splash screen or anything else show up?
or do you get an error or just nothing?
also, could you please navigate to ‘C:\Users\[USER]\AppData\Local\MoBro_Local’ and search for a file called ‘error.log’
if you could upload that somewhere or just send it to us, we can have a closer look at what's going wrong
Upon reading your comment i realised i did not clear user appdata. I cleared that and it works fine now. Ty!
Hi @Seraksab a new problem has arrived! :D
I've always used Libre Hardware, without ever really installing it so i asummed it downloaded with modbros. Yesterday when i got it working, i could still use it. Today, i cant. I also decided to download hwinfo to see if i could some more data. But i cant use that either? It just says it isnt installed. Any ideas?
Yes, LibreHardwareMonitor is already bundled with MoBro, so no need to install it separately.
Do you get any error or does it just show no data any more?
Regarding HWiNFO: did you enable shared memory like described here?
I indeed got HWiNFO to work with the enable shared memory, so thats fine. No errors or anything. Just says its not in use. Reinstalled again, did nothing.
You are running Windows 10, right?
Could you open ‘http://localhost:42001/api/sensors/meta’ on the PC you have MoBro running on and share me the response you get?
