MODBROS MONITORING SERVICE NOT RUNNING
I've been getting this message “MODBROS MONITORING SERVICE NOT RUNNING” since I've installed the software on my PC, restarted the system as I still same, checked the services.msc and no Modbros services visible. Then ran ModBrosMonitoringService.exe in Local still same. Help!!!!!!!!!!!! going nuts here.
Appreciated
there should be a "ModBros Monitoring Service" service indeed. Have you tried running the installer again?
Yeah, probably around 15 times now
Hi @Vil'Sa
yeah from the services list you posted you are indeed missing our service. This should normally be automatically installed.
However you can also try to manually install it:
- open an administrator command prompt (or Powershell)
- got to: C:\Users\[YOUR_USERNAME]\AppData\Local\MoBro_Local
- execute: .\ModBrosMonitoringService.exe install
You should then see the service listed
If not, please post the error you are getting when executing the command
This is what I get but changes nothing…
To install the service you really have to execute the command that I posted above.
From the screenshot it looks like you only started the service. So its not running as a service and once you close the console window it will be gone again.
Apologies, just figured it out. My User name had ' in it. read another thread, changed the name restarted and bingo.
