no wireless interface detected
hey guys so i have just installed the app and program and software on the pc and the sd card i flashed successfully
wen i plug everything in
i get stuck on a screen that says
wireless interface not detected
am i missing something ?
i have ther smallest module board
and using it with a 7" and a 4"
i know to only use 1 screen i just nbought 2 for 2 different reasons..
how can i get it to work ?
Hi @song
Something general first about using a forum before we address your problem:
It's great that you used our forum to reach out to us. But creating one topic for your problem is enough.
Randomly spamming multiple unrelated topics won't help you get an answer faster and just annoys us because it's getting harder to keep track of issues. So please refrain from doing that in the future.
I've deleted your comments in other topics.
Now regarding your issue:
It seems your'e using a Raspberry Pi that doesn't have Wifi.
Could you check which exact version of the Raspberry Pi you are using? If you can't find it you can also just link the one you bought.
