Raspberry pi 3B + Undervoltage
I have installed the raspberry pi image on a raspberry pi 3B+ with a 5 in screen.
I keep getting undervoltage errors, so the app crashes once the computer goes to sleep.
I have tried to power it from a good USB cable and a USB header directly on the motherboard, but neither worked.
How can I fix this?
Thanks in advance!
Replies 1 - 4 (4)
Hi there,
Motherboard USB header won't serve enough power to your pi+screen. You need at least (in my case it works) 2.1A power supply. The recommended power is about 3A.
@magnificent3 Thanks a lot for your help. I will do that. I was hoping for a sleeker look, but that will do.
Can someone post a link for an adapter they have found to work, I have tried several including 2.1 and 3 A plugs. Thanks
https://www.amazon.ca/gp/product/B01LPLPBS8/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
This is what i bought. Seems to do the trick. It's raspberry pi branded power supply.
