Is possible to do a horizontal layout on the dubbadhar theme? I change the screen orientation on the modbro setup but on the screen is not fill properly. I'm using Raspberry Pi 4 and Lamptron HM070 7 inc screen.
Thank you
Hey @DHiza
There is a breakpoint in the CSS files of that theme that regulates that. If your screen aspect ratio would be ⅓ or less it would change to that:
The easiest way would be to wait a few weeks until our theme customization is ready - with that you can organize your screen and widgets to your liking. Currently you would need to code some css like described in our blog posting here.
Hey @DHiza
Hi GhosTz,
I'm really not familiar with css and stuff like this. Can you tell me what I have to change to change it like this?
Thanks,
René
Hey @ReRoPa,
We'll release the Theme Customization next week so you will be able to move these components around however you want. I'll say wait a few days and no need to do css or anything like that ?.
@GhosTz this. Answer is even better than explaining how to do it ?
thanks a lot
@GhosTz can you say when it will be released?
@ReRoPa we've released it an hour ago ?
You should see an update icon in the top right corner of the app!
@GhosTz seen it :-) Thank you.
