Wireless Hotspot created by Pi load a blank page
I have a raspberry pi zero w, and I have flashed the modbros image. During the setup at the stage where the Pi creates a wireless hotspot and to access the configuration, it asks to go to https://192.168.4.1. I have connected to the MoBro_Configuration hotspot on my phone and go to the link but nothing loads - it is just a white blank screen. (my mobile data is switched off) and I have tried this with a MacBook but the config does not load on https://192.168.4.1 - any idea on what might be happening?
Hi @Johnsvpaul
could you try to load the page over http instead of https?
Https isn't enabled if I recall correctly, since the page is only served in your local network.
But I guess that's something we could easily change in a future version :)
Ah yes that was the problem, http works. Thank you!
