Chromium issue on Pi Zero 2
I'm seeing the following Chromium issue in the logs when trying to connect. Any ideas? I just end up with a white screen on the display.
25.07.22 12:15:51 [1][47][0x0][service_discovery] checking previous host on 192.168.68.106 with key 'mobro'
25.07.22 12:15:51 [1][47][0x0][service_discovery] MoBro application found on IP 192.168.68.106
25.07.22 12:15:51 [1][47][0x0][helper] stopping process: feh
25.07.22 12:15:51 [1][47][0x0][feh] switching to image /home/modbros/mobro-raspberrypi/resources/found.png
25.07.22 12:15:57 [1][46][0x0][helper] stopping process: feh
25.07.22 12:15:57 [1][47][0x0][chromium] switching to: 'http://192.168.68.106:42100?version=12.3&uuid=00000000f1c7b53c&resolution=600x1024&device=pi&name=Raspberry Pi Zero 2 Rev 1.0'
25.07.22 12:15:57 [1][47][0x0][helper] waiting for chromium to become available..
dpkg-query: no packages found matching bluealsa
25.07.22 12:16:00 [1][47][0x0][helper] waiting for chromium to become available..
[2979:3049:0725/121601.310505:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[2979:3049:0725/121601.311591:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[2979:2979:0725/121601.370787:ERROR:component_loader.cc(186)] Failed to parse extension manifest.
libEGL warning: DRI2: failed to authenticate
[2979:3049:0725/121601.469445:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[2979:3049:0725/121601.471515:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[3044:3044:0725/121603.590684:ERROR:gpu_init.cc(441)] Passthrough is not supported, GL is egl
[3044:3044:0725/121603.825519:ERROR:viz_main_impl.cc(162)] Exiting GPU process due to errors during initialization
[3099:3099:0725/121604.126280:ERROR:gpu_init.cc(441)] Passthrough is not supported, GL is swiftshader
25.07.22 12:17:04 [2][47][0x0][background_check] MoBro on 192.168.68.106 reachable
I can access the URL fine on my network and can ping 192.168.68.106:42100 from the Pi, so no issues there.
Hi @Ezonas
That's weird, we've also tested the image on a Pi Zero 2 ourselves and it ran perfectly fine..
Is the MoBro logo or any other page visible on boot? Or do you only ever get a white screen the whole time?
Did you manually change the configuration or anything else on the Pi?
Hi @Seraksab
Thanks for the reply. This is a fresh install as it started randomly, no custom config other than rotating the display 90.
Yes, I get all the MoBro images, so Splash, WiFi, looking for PC app, found PC app, then white screen (this error) and the Pi does not display in the connected devices list on the PC app.
Strangely though, if I leave it on the white screen long enough (several hours) it will randomly connect and show the theme. But then I get the same every time I turn it on.
