Dashboard problem
After installation to the 0.0.22, i can't install the default dashboard, no Althern, Fallout etc, what should i do to fix this.
Unfortunately those old themes are no longer compatible with the current version of MoBro.
The current version is a lot more flexible and customizable compared the old version from a few years ago.
To achieve that we basically had to rebuild it from the ground up with extensibility via plugins and widget packs in mind. As a consequence, the old "themes" are unfortunately no longer supported in the current version, as they were based on a fundamentally different design from a software perspective.
You should be able to rebuild pretty much any of the old "themes" in the current MoBro version though. You can also checkout the #dashboard channel in our Discord server, where other users have shared some of their configurations.
