I have a wierd thing where despite modbros and hwinfo both being run as admin modbros doesn't recognize hwinfo. Open hardware and Libre mostly work, though neither can consistently get my cpu temp.
1 - 2 (2)
Did you start HWiNFO in sensors-only mode as described here in the FAQ?
If yes and it still does not work try the following:
close it and start it again normally (with 'Sensors-only' and 'Summary-only' NOT selected)
go to Program -> Settings
under the 'General / User Interface' tab make sure Shared Memory Support is enabled
click OK, close hwinfo and reopen it in sensors-only mode
I did not start it as described in the faq, and starting it sensors only did the trick
Topic has been closed.
