ModBros wont starts anymore
Today I got a fast power failure, like a spike. PC reboot and ModBros cant start.
Any other softwares is working, so I tryed remove and install(MoBro - ModBros Monitoring Service-1.0.0-beta5 Setup) again, but now, modbross even wont open the instalation windows.
I got no erros, just showing modbros logo, like starts instalation and closes after that, and it showing in task manager, but I get no windows to reinstall.
If I close the 3 modbros processes, the issue keep doing and always I try install the 3 processes back to task manager
Windows restarted many times, all working, others installations is working too, but modbros no.
Win10 19042
Any tips?
Ok, I've create a new windows user, just for test and modbros is installing normally. So, is there way to move modbros back to the old user?
SOLVED
Hi guys, I just remove the folders modbro and mobro_local in C:\Users\user\AppData\Local.
Now all back to normal :)
thanks!
Hey @neomvll,
thanks for also posting the answer. We had this issue before, that a json file (settings) was corrupt after writing it to the disk. This might be due to the power outage and it could not finish writing the file.
