Over Bluetooth
So is it possible to set this up over Bluetooth? Was originally thinking about having it over USB and Im following the other thread but then I thought about over Bluetooth. Is this possible?
Hi @Makipsee
In the current implementation the Raspberry Pi needs to be able to communicate with the PC over ethernet or wi-fi.
The method that's described in the other thread that enabled communication over USB makes use of RNDIS, which essentially provides a virtual Ethernet link that runs over the USB connection
You could have a look at the pull request here if you're interested at how exactly the version over USB would be implemented: https://github.com/ModBros/mobro-raspberrypi/pull/6
Unfortunately we haven't really found the time yet to integrate this into the image :/
Now I haven't looked at it in detail, but I guess you might be able to do something similar over Bluetooth tethering.
Not 100% sure tough, but certainly worth tinkering around a bit if you got the time and interest ;)
Yes I was first pointed to that thread. I am very limited on what I know how to do when it comes to those things haha. I ended up getting lost while reading the other thread.
