For my OnePlus 6T I have to set the resolution to 861 x 412 to not have white lines or scroll bars. If I click use device resolution it gives me 891 x 411 with scroll bars. But, the real question is where do those numbers come from? The screen resolution of the phone is 2340 x 1080, but that really doesn't look right on the phone. So, can you tell me why the resolution you enter in the Them Configurator doesn't match the phone's resolution?
Hi @emedlin, that is due to how the rendering in web views work. They don't use the actual pixels a screen has on mobile devices but is based on the PPI of the screen, that's why the resolution don't quite match.
@Dave, can you share the math on how to calculate the resolution you enter. It seems when you click use device resolution it gets close. But, I still had to tweak it.
@emedlin, its based on the CSS specification https://www.w3.org/TR/CSS21/syndata.html#length-units. So its based on points which are equal to 1/72nd of 1 inch. How many pixels was your resolution off? We may have a rounding issue in the calculation.
@Dave, when I click the button to use device resolution it gives me 411x 891 with scroll bars on the phone. I tweaked it one pixel at a time and ended up at 412 x 861. This is for a OnePlus 6T if it matters.
@Dave, I just tried it with beta11 and it still gave me 411 x 891, but the phone doesn't have scroll bars anymore. However, I can drag the screen around on the phone to show the extra space that 411 x 891 gives me.
Hi @emedlin thanks for the details, I will see that we can fix that in the next version.
Hi @emedlin, we have just released a new version 1.0.0-beta12, that should fix the issue you are having with the 1 pixel difference. Just hit the “use device resolution” button in the customization screen :)
@Dave, worked perfectly. Thanks.
