AV out not working on RPI 3 B+
It works fine while using HDMI, but not AV. I know my AV cables/display work, because they work fine with raspbian, but not this. If anyone has a fix, that would be great. If not, is there a way I can run this in rasbian, as it works with my setup?
edit: using RPI 3 B+
Hi @squidud
if your AV cables and display work on Raspbian, then they should also work with our image as it's based on the official Raspbian Lite.
Maybe you need to adapt a few settings in the /boot/config.txt file to get it working. Ours is configured for HDMI per default.
You could just compare it the one on your working Raspbian install to check for differences.
Other than that you can of course use MoBro on a standard Raspbian install as well without our custom image.
Just check out the guide here.
