Can I install PiHole on the same Raspberry Pi as the monitor?
I'm got the monitor running beautifully on my Pi 4. Thanks for a great app! I was wondering if I could install PiHole on the same Raspberry Pi. I've got it on a reserved IP address on an ethernet connection.
Replies 1 - 4 (4)
Hi @PolCat
Technically you should be able to install PiHole on our image, as it's basically just a slightly modified version of the official Raspberry Pi OS with our software already pre-installed and set up.
However I have never tried it myself so I can't tell you 100%.
You might well run into some minor issues on the way.
Thanks Seraksab. I'll let you know how I get on
How did it go? Did you install via SSH? If so, what credentials did you use to login?
I installed it no problem. Works great!
