So, i finally managed to finish my monitor screen and wanted to share with you people. I am not done with the layout, for instance the line chart and bar in the bottom right are both for FPS, just wanna see which i like more… It took a while for the screen to arrive, and turned out it was broken, so had to buy another one… Had some leftover wood to make a frame, might paint it black later.
Anyway, here goes (sorry for the mess around :) ):
Hi @pcvdbroek, wow that looks pretty darn good! Nice G29 btw ;)
Hi @pcvdbroek - how did you manage to get the FPS in the Dubbadhar theme? I was able to pull in the framerate using HWinfo into the main Hardware monitor, although when trying to add this as a widget source, its not available.
I am keen to understand how you were able to achieve this so I can replicate
I am using Aida64 as source for this. So it can't be done with modbros alone, you will have to install that too, so modbros can use it.
