Use device resolution issue
When I select “Use Device Resolution”, nothing really changes….I only see a portion of the dubbadhar theme on my tablet. The stated resolution of the specs of the tablet is 1280x800, but there is no change when setting that in the Theme Configurator.
Hi @TanktheFrank
You can think of the resolution (the one that you set in the theme configurator) as the total size of the canvas you have available. This should match your devices resolution, otherwise there will be scrollbars as the canvas wouldn't fit 1:1 on the devices screen.
Now changing the size of the canvas currently doesn't also automatically change the size of the widgets that are on it.
So you will basically have to resize, reorder or add/remove the widgets in order to fit into the 1280x800 pixels you set as your resolution.
You can easily do this within the theme configurator by just drag and drop.
