Wifi Configuration
Hi, I can't seem to get my Pi 4 to connect to my wifi. I have verified all settings are correct and applied them three times now. If you have a solution for this that would be great. Thank you.
V12.3
Raspberry Pi 4 4gb Ram
Wifi enabled
Hi @Anonymous_549
After applying the configuration, does your Raspberry Pi reboot successfully?
Also what do you see on the screen?
Are you connecting to a 2.4GHz or 5GHz wifi network?
If it's the latter, please also make sure to select to correct country
Is your Pi in range of your router?
If the Pi is placed e.g. inside a PC case, this might cause problems if the signal is already weak.
I do have a Pi 4 here myself and just flashed v12.3 again for a quick test. Mine is able to connect without a problem to both my 2.4GHz and 5GHz network
If it fails to connect on the first reboot right after configuration (the “failed to connect..” screen is visible), you can also try to manually shut it down and power it up again once more. at least this has already helped me in some cases
