No channels for motherboard Fan Speeds
GDay Guys and Gals,
I have an ASUS ROG Strix X570-E Gaming motherboard which uses the Nuvoton NCT6798D sensor controller.
I have been using Mobros v1.0.0-beta13 on Windows 11 Pro and the RPi v12.3 image on an RPi3 for a little while now (Love It!!) and I have noticed that both LibreHardware and OpenHardware do NOT show any channels for motherboard Fan Speeds at all.
When you select a channel to display > LibreHardware or OpenHardware > Motherboard it shows options for Fan Control #1 through #7 and all of theses channels display 0.0% regardless. There are no options to show the Fan Speeds at all, only the controlled percentages.
OpenHardware displays the Fan Speed under Nuvoton NCT6798D > Fans as Fan #1 through #7 (If I am not mistaken, I only see #2 & #5, Fans and Pump for my H100x).
I am able to display my RX 5700 XT GPU Fan Speed with no issues.
I am cheap and do not want to install HWiNFO64 or AIDA64, so are there any other ways of displaying my CPU Fan Speeds at all?
If it matters, I am using a custom dubbadhar skin.
Any help would be gratefully appreciated.
Regards
Andy M.
