Trojan fix?
I have seen the post where it says you can use an updated nightly build of LibreHardwareMonitorLib.dll, but if I get the latests it doesn't work.  I rename the old one to LibreHardwareMonitorLib.dll.bak and copied the new one into C:\Users\{user}\AppData\Roaming\mobro-data\service\plugins\modbros_librehardwaremonitor.  When I reload the plugin or restart ModBros it fails to load the plugin.  Anyway to fix this?
I also noticed not only does C:\Users\{user}\AppData\Roaming\mobro-data\service\plugins\modbros_librehardwaremonitor get flagged as a directory with trojans, so does  C:\Windows\SystemTemp\UDDD87D.tmp and some other similar named tmp files.  They are flaged when I load ModBros.
Hi had the same issue, and had to quit for a simpler solution that gave more stability and overall performance, and most important of all, more flexibility on designing my own dashboards.
I ended up giving up on the windows mobro software, and use only aida64 with a custom python made app that does pretty much what mobro does, regarding the option for adding new themes and starting on windows boot. I ended up building a complete custom made dashboard for my Pi running on a 5'' Screen.
