Problem connecting raspberry to the wifi network
Hello everyone. I followed the installation procedure of the modbros program and the installation of the image on the raspberry.
I configured the raspberry following the guide. My problem is that if I connect and configure my raspberry to the LAN network, the LCD display works by viewing the values of the sensors, but if I use the wifi network this does not happen. My aim is to insert the display inside the case and use the wifi to read the sensors.
How can I solve?
Hi @Adriano_68
from your description I don't quite get what exactly isn't working when you're trying to set it up over wifi
like does the Raspberry Pi not connect to your wifi network?
does it connect but can't locate your PC?
or does all of that work and just values on the theme are missing?
