Run stats via lan cabel
Hello, I'm new to the forum and the whole mobro thing , so what I am trying to do is run the app on my phone via a lan cabel , I don't use WiFi, i tried running it with WiFi and it works fine , but I position the old phone I have near my monitor and use a network adapter , my phone runs fine with lan cabel internet but I'm getting issues when I run the mobro software ? It only likes to run with WiFi , how to run it from Ethernet?
Hi @Christo
Unfortunately the current Android app will only work over Wifi.
We might add support for ethernet in the future. But as we're already busy with other stuff and its also a pretty niche use case, it's not a priority for now. So no real ETA.
Thanks for bringing it up though ?
For the meantime you could try to just use a browser instead of the app. It's basically the same as described here for the Raspberry Pi
