T sensor value incorrect
I am only monitoring temps.. CPU. GPU. and Water T sensor, the water T sensor is available from HWinfo but the value shown on modbro program is different then the value shown on HWinfo.
Hi @mattv
Are you referring to the water sensor value shown directly in the MoBro desktop application or in a theme e.g. on the Raspberry Pi?
Could you provide a screenshot of the MoBro application and Hwinfo side by side, so that both values are visible?
https://imgur.com/gallery/2KyTH8d
It would not let me upload the picture directly for some reason so I put it on imgur.
it’s also really weird because it shows me the Correct temperature when I’m selecting it but then the wrong temperature on my monitoring screen…
https://imgur.com/gallery/sY5Djv8
Yeah that doesn't look right..
I can also reproduce the issue on my end with different values from HWiNFO.
We'll look into it and aim to fix it with the next upcoming release.
Oh and by trying to post an image you also just made us aware of a forum issue regarding that. So we will look into that as well ^^
It’s really strange because when I select the value while setting up the monitor it shows the correct reading.. But when applied it reads a different number
this is a really cool piece of software, and you should be pitching it not just for raspberry pi; but also a desktop app, people like myself who are running custom loop water cooling have have different things they want to monitor and one quick easy to glance at place..
out of everything that I have tried yours is the most user-friendly despite having the wrong value for my tsensor
Thanks for the kind words :)
Also have you tried the new beta6 version that we released last week?
Your tsenser issue should be resolved now.
