Hey, i'm using the theme Astern V1.0.0, It doesn't show VRAM usage, instead it shows “NaNGB”, I've tried the other themes and it still doesn't work. Thanks.
1 - 1 (1)
Hi @Faria, have you tried one of the new customizable themes? Do you also get NaNGB for the VRAM when you directly select the data point either from libre- or open hardware monitor?
