Waterflow monitoring
Hellow Fellow Bros,
Im planning to buy a flow meter for my system.
Its a custom watercooled system and i wonder if anyone has a waterflow monitor running on the Mod Bro app.
If so what waterflow meters are supported? Or is just any sata waterflow meter good enough?
I just wonder since i still need to buy one and i dont have one laying around to test it my self.
Hey @Angelicjack,
It really depends. The MoBro app itself does not monitor the data.
All the data shown inside the application are monitored by our 3rd party plugins. Currently there is Open Hardware Monitor and Libre Hardware Monitoring installed out of the box with support for HWiNFO and Aida64 integration (so you would need to have them running next to MoBro).
If your sensor is picked up by these you will be fine.
Hope that helps
