Wuhuuu, finally...!!! :)
Finally the new version.
And to leave feedback, here is what i found.
On the dubbadhar Theme the donuts are not changing when modify or add things like from hwinfo.
I deleted everything except of Aio Fan und CPU Fan and it still show me the standart donuts.
Raspberry reboot isnt helping.
Can you also tell the people about how many icons on the different screen sizes fit?
Like i am using a 3,5" Touchscreen.
Is it possible like keep it that small but make the screen movable? So that you can decide what to keep an eye on if you know what i mean?
But anyways... I LOVE THIS APP!!!! Keep that great work up!!
Hey Pete,
changing your widgets in the app has no influence on the external devices like a pi.
If your donuts stay flat we have issues getting the correct data for your hardware. In a later version you will be able to map those values by yourself, if we are not getting the right ones.
Could you please send us the response, when you go to http://localhost:42001/api/sensors/data on the PC running MoBro, to info@mod-bros.com
Thx ~Dave
