How to rotate screen with mobro software installed?
Noob
in
Raspberry Pi Image
I'm currently using this display via hdmi: https://www.amazon.co.uk/Elecrow-Capacitive-Interface-Supports-Raspberry/dp/B07PQQGP7R/ref=pd_ybh_a_8?_encoding=UTF8&psc=1&refRID=0GZWDCZH2Y4EXA079JSJ
My whole setup is running on a raspberry pi 3 B+
Thanks in advance.
1 - 1 (1)
Hi @Noob
for the display you linked and and the Pi 3 B+ this should be doable by setting the display_rotate option in the /boot/config.txt file.
Like described over here: https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
