LCD screen wont work after installing Mod Bros, Open console in Mod bro program?
Hello!
This is a really cool project!
I am having some issues tho, when I first got my raspberry I installed Rasberry IO and the LCD screen just didn't work, however I got it to work when i typed some scommands in the console..
But when I installed Modbros software the console commands seem to be gone because I can't get the LCD screen to work.. Is there anyway to open the console in the Modbros program?
I can see the raspberry when I connect it to my monitor and not to my gpu to use the LCD screen.
Using mouse and keyboard!
With Best Regards,
Emil Lundberg
Hi @Emil7813
To set up our custom Raspberry image, please check out the guide here: Setup
If you still need to manually install a display driver after the setup, just can still do that over SSH.
Instructions here: Display-Drivers
