Not working v12
I flashed 2 brand new 32 gb micro sd card and I noticed my screen wasn’t appearing at all, I flashed with the raspberry imager and balena etcher. Is this a common problem or is there a fix I could use.
@Cody Thompson
Did you have it working with a prior (v11) version of the image before?
Or is this your first time setting it up?
Also what screen are you using?
It is my first time setting anything like this up. And I’m using a normal 27 in monitor to test things out on first
So I guess the monitor is connected over HDMI then, right?
Which Raspberry Pi model are you using?
If it's a Pi 4, make sure to connect the HDMI cable to the micro HDMI port that is closer to the USB-C power connector.
