Raspberry Pi flip verticaly
Is there a way to flip the pi‘s display vertically?
Hi @PapiGordo
Yes flipping or rotating the screen is normally not a problem.
But the way you do it depends on which display you are using.
Is your display connected via HDMI cable or directly to the GPIOs?
Hey, I'm also trying to rotate my screen; it is currently displaying in landscape but my screen is installed in portrait. I have my display connected via hdmi
Also needing Help w/Rotating my Screen Rapberry Pi3 A+ on Rasp 7" display connected through onboard ribbon cable…the way it has to go in the Rasp 7" case flips screen 180 and need to bring it back 180..?
Thanks
