stuck on boot
Senu
in
Raspberry Pi Image
hey, id like to start by thanking you for your work on this project <3
I have ran into an issue on set up. my pi gets stuck in booting up.
the last thing it posts during start up is as follows.
“Started the PHP *CGI Process Manager”
the monitoring UI never comes up. it says its connected to my network and all that jazz, any ideas? thx again
1 - 2 (2)
Hi @Senu
First of all thanks for the kind words :)
Did your Pi work before or did this already happen on the first boot of our MoBro image?
Also how long did you wait before shutting it down again?
The pi worked before this. first boot/pre setup worked. i waited like 30 mins.
i have sense just flashed a different sd and it is working now. But thank you for the reply <3
