Waveshare 7inch 1024x600 Blackscreen with v
weezybaby307
in
Raspberry Pi Image
Hello mates, top project ! ! !
But i only got a blackscreen with v12. 3
got this display. https://www.waveshare.com/7inch-HDMI-LCD-C.htm
selected it in the setup wizard and still no luck. tried default settings and the same problem.
I don't touched the config file.
I tried the v11.1 and everything works fine.
is there a fix for this out there ?
sry for my broken English ?
thanks in advance
1 - 3 (3)
You should add the following code to the config
max_usb_current=1
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_drive=1
in v12.3 ? will give it a try. thx
magnificent3
max_usb_current=1
hdmi_drive=1
tried it with these line and still no luck...BUT
I added these line in the config and everything works fine now with v12.3
dtoverlay=vc4-kms-v3d
