Wrong wifi password
I've been trying connect to my wifi. I'm sure I'm putting in the correct wifi password but it never connects.
Then it goes into creating the hotspot,sometime the hotspot appears but I can't get to connect to it again the only way is to reflash the sdcard.
Wifi is 2.4 - password is not long removed the long one.
Hi MaMoUs
Just a few questions so we can narrow down the cause of your issue:
What Raspberry Pi are you using?
Which version of the Pi image are you on?
Are you connecting to the Hotspot and then using the configuration page to select the wifi network and set the password?
Seraksab blog.reply.wrote:
Hi MaMoUs
The answers to your questions
1- I'm using Raspberry pi 3 A+
2- the latest version. 8.7 i guess
3- yes i am when i put the wifi password the hotspot turns off then tries to connect to the wifi then it fails and it says it will creat the hotspot again. Sometimes the hotspot will show up again but i can't connect to it it fails on windows / android / ios.
I got it to connect after changing my wifi password, guess my password is too complicated for it? Lol
Topic has been closed.
